EcuFlash/Ceddymods help?
HX35GSX
89
Mar 21, 2011
Phoenix, Arizona
So I already bought a OP2.0, flash adapter and downloaded evoscan and eciflash. I would like to have control over the readiness monitors and log my PLX m300 WB with evoscan. I have read the entire ecuflash thread and much more(literally days of reading). Ive also watched all the ecuflash videos. I guess I just want to make sure I download the correct ceddy file. I also read about some problems with bigmaps and logging a 2byte load with evoscan. Can someone elaborate on this for me? Any suggestions are also welcome as this is the first time I'm doing this. I would have posted this in the Flash thread but I'm not able to.
I previously ran ceddy mods with big maps with no issues. Logged ecuflash with 2byte load with no issues as well. What else are you asking? If there is something specific let me know should be able to help
Here is a link to a guide that helped me out when I first started tuning. Granted it is based off of the evo but has a great deal of good information in it: http://www.evoscan.com/ecuflash/Merlins EcuFlash EVO 7-8-9 TUNING GUIDE-V1.7a.pdf
Ok... So I've flashed my ECU with the simple Ceddymods. I have a few issues though. I swapped out my 450's for some PTE 1200's because I plan on turning up the boost very soon. I used .390 for latency and 1109 for the scaling. I took some logs for LTFT lo(idle) and mid(cruise). When taking off from a stop it bogs down and kinda misfires. I'm sure this has to do with the injectors as it wasn't doing it with the 450's. Another thing is that I disabled DTC P0141 in the periphery bits but I still got a code. Maybe I didn't "disable" it? Peripherybit2, bit11 is set to "0". I also enabled the readiness monitors but I doubt that has anything to do with it though. My AFRs are also all over the place! What do I do next?
These are my latency values:
4.69volts===3.825
7.03======2.205
9.38======1.515
11.72=====1.185
14.06=====0.975
16.41=====0.825
18.68=====0.705
My apologies if this is in the wrong forum, I forgot I can post elsewhere now. Technically, I'm a newbie on this specific subject.
