bling5tatus
- 1,603
- 121
- Sep 23, 2005
DFW/Austin,
Texas
Haha, ok. Patience. Are there any non-nitrous dsmlink cars breaking into the 10s?
Into the ten's? I don't have time to generate a list, but sure. My buddy Brian ran a 10.1 @ 140 on pump gas and a 35r last fall. Self tuned with Link V2 and a GM MAS. The car weighed over 3000 lbs with him in it, and he's never sprayed the engine either.Haha, ok. Patience. Are there any non-nitrous dsmlink cars breaking into the 10s?
I'm sorry, I know this is going to sound ridiculous... but I meant 9s.
I came across this today and remembered this thread. It's in HD too, so all the better I suppose.So are there any logs/dyno sheets or videos
Has anyone made any real power on V3 yet? I just ordered my V3, and right when I got it, I went to Pinks and a friend of mine is having an apparent problem with it.
As of right now, I am not making anything worth mention, but he is over 700 whp and is having problems with it shutting down, killing power, maybe due to the amount of air flow coming in, from what I understand he is one of the few highest HP cars on V3 yet. Also from what I hear the other guy with very high HP is having a very similar problem.
I am trying to get an idea, because like I said, right now it is not a big concern, but in the future I would like to run a 2.4, HTA 35r, 100% meth. I would like to know if it is in the program, because if that is the case I would like to return it before I continue.
From what I understand there is ALOT of high HP cars on V2, but few on V3 yet.
You mean John Wood? He's definitely having a problem; a couple actually. The first of which was a collapsed flex section in his exhaust causing a serious loss of power. The second being that crazy loss of power after quick shifting. But at this point, I just can't see it being related to V3. If it is, we'll most certainly fix it. I really feel bad for the guy.I just ordered my V3, and right when I got it, I went to Pinks and a friend of mine is having an apparent problem with it.
This one you've got me stumped on. The only other guy that had a problem recently (that John felt might be related to his own) tracked his issue down to a GM MAF installation problem. Is there someone else?Also from what I hear the other guy with very high HP is having a very similar problem.
Oh cool. So are there any logs/dyno sheets or videos showing how the speed density was a major improvement over mas?
It shows switching not only the air metering device, but the tuning tool as well, so it's not really a valid comparison.
A valid comparison would be the same tool using a MAF, followed by the same tool using S/D.
See I understand your point, but I figured it would still count since your still changing from a MAF based tuning system to an SD system. But I made sure to include that in the post that it wasn't the same as switching from V3 with a mas to V3 SD. I can remove it if you like as to not give people a wrong impression.
The big gains up top I attribute to not having timing control with the AFC and for the AFC tune I was simply turning the cam sensor to adjust the whole timing map.
This is not my dyno graph it is from a member Lowell Foo on the DS-Map forum. The mods stayed the same, according to his post I would assume there were some timing changes made, because he mentions messing the timing when tunning with the SAFC by turning the cas.
Boost was 21psi for the DS-MAP pulls and 18psi with the stock ECU/AFC. 20psi with the AFC ended up pulling timing and power stayed the same, although it made slightly more midrange torque. Injectors are 680's.
That alone increases torque by 9%:Boost was 21psi for the DS-MAP pulls and 18psi with the stock ECU/AFC.
Thomas Dorris
I guess better wording would have been, felt like he might have beenHas anyone made any real power on V3 yet? I just ordered my V3, and right when I got it, I went to Pinks and a friend of mine is having an apparent problem with it.
I finally heard back from this other guy on his weekend results. Apparently the original breakup related to GM MAF goofiness was cured as I mentioned before, but he still has a strange power loss that, so far, does not have any clear explanation. He has not posted logs and neither he nor John have been able to free the time/energy to dig into this.The only other guy that had a problem recently (that John felt might be related to his own) tracked his issue down to a GM MAF installation problem. Is there someone else?
