ECMlink ECMlink V3 Disconnects!
Abe'sGST
734
Aug 27, 2011
Goldsboro, North Carolina
Hey guys, I have searched and cannot find a similar case to mines. Just recently I purchased v3 full from someone on tuners. Installed it and it worked just fine. Recently it's been disconnecting, it happens everytime I stop streaming a log or if i decide to change some adjustment (ex. TPS) it disconnects. It will not connect again unless I exit the application, turn the ignition off and disconnect the usb cable. After I do all that and try to connect again, it connects just fine. If I don't do all that and just try to reconnect after it disconnects it says "no response received". Sometimes right before it disconnects it gives a message saying that port is already in use. This has been really annoying since i can't make any adjustments without it disconnecting. I know this may be confusing but any input will be greatly appreciated. Thanks.
-Abe
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
