ECM link problems
shad0wsoda
53
54
Mar 5, 2013
Colorado Springs, Colorado
So I've just recently bought a 98 gst and the previous owner gave me an ECM link disk and cable to use. So I've installed the disk on my laptop and when i plug the cord into the car and the laptop ill run the program and all that happens is this screen(this is the screen that comes up before the actual program loads) then the program closes. In devices it shows the COM3 is connected but I've looked around for solutions and i cant seem to find any(idk if its drivers? but those should be on the disk right?).. any help would be greatly appreciated
Thanks!:cool:
snowboader....thank you for your help.. this was also my problem..everything great now.. the only exception is that I cant get a connection... ive assigned the port to com4 as it shows in my device manager.. and still no connection.. can you tell me where to start?..as I feel im doing everything right on the wiki..
thank you in advance
trevor
yes sir...in the car as we speak
it says com4: no response received
action raised exception
even thou it flashes..could it be the cable?
ok cool....ill continue looking over the wiki and scanning the ecm forum for possible fixes....thank you for your help...I appreciate it
trevor
