Eclipse has no power whatsoever
jmichel
Mar 21, 2010
Ballston Spa, New York
So I was replacing the valve cover gasket (Friday night) and went to start it up 24+ hours later (Sunday Afternoon) and got a click and nothing. Though it was the battery. Tried jumping it, nothing. bump started it with my brother and it started fine and ran well. Got a new battery for it today and installed it. Everything came on but I got the same click. Went out 10 minutes later to try again and there was no power to the car. Does anyone know what could have caused this.
*side note* Friend who was installing the gasket touched the ecu with the ratchet while tightening the bolt to the positive terminal and it sparked. Would that affect anything? (I was able to bump start after this happened)
everything is grounded, all fuses are good, and its a 420a engine so the ecu and batter are basically next to each other
smell the ECU and be sure it doesn't smell fishy. If it does It's almost 100% fried, but if not check with an Ohmmeter what the resistance is to the starter. I feel the starter is your problem because it clicks, but doesn't engage, but when you "pop" started it you didn't need the starter, but your spark plugs were firing because it ran, so I assume your ECU is fine.
Yeah I can almost guarantee that your starter is either bad or has too much resistance to it. Your ECU is fine if your car ran when you pop started it with the clutch. Think, since the jump didn't work because the starter is bad and wont turn over, it just clicks on. And when you pop start it you don't use the starter, but rather the speed of the transmission to engage the flywheel with the clutch to turn over the engine to start it.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
