EBC install: internal wastegate disconnected?
raptoranderson
195
23
Sep 24, 2015
Graham, North Carolina
I have a '98 Eclipse GST with a 20G turbo which has an internal wastegate. I have a GFB boost controller and just went to install it in my car when I noticed that it seems as though the wastegate is improperly connected ...
The pictures I have aren't great, but you'll see the nipple on the top of the wastegate is attached to a rubber hose which runs to the passenger's side of the car and attaches to some sort of black box which is also connected to the intake pipe via a rubber hose and then has a set of wires exiting from the bottom of the black box and running to the underside of the fuse box.
I thought the wastegate operated by using a pressure source? The intake pipe isn't under any load and isn't even a vacuum. Does this mean that the wastegate has been made useless?
The black box is the boost solenoid located under the intake pipe on the passenger side of the car which is hooked up to your wastegate.
How does the boost solenoid know when to open the wastegate? And how does it open the wastegate if it's not attached to a pressure source?
I'm saying that the wastegate doesn't have anything to force it open because there is no pressure being applied to the wastegate actuator. The vacuum line coming from the wastegate is what will have the air in it to push the wastegate open, but the vacuum line coming from the intake pipe won't be under any pressure since it's before the turbo, right? So where does the boost solenoid get the pressure with which to open the wastegate actuator? :hmm:
You're all good :D I'm just trying to figure out if hooking-up an electronic boost controller will actually do anything LOL I suppose I can just hook it up temporarily and see if it makes any changes to the maximum boost and then if it doesn't to go from there
Hook the WG up to a boost source and leave the solenoid where it is, it just wont function.
If you want to try the EBC then place it in between the boost source and the WG and watch boost carefully.
What is the boost source though? The boost solenoid? And where does the boost solenoid get its boost source from?
Any port between the turbo and the throttle body....actually any port on the manifold but it is always suggested in the intake tract between the turbo and the TB. Sometimes you have to make a source. I had to drill and tap a hole in my compressor housing on my Holset to add a fitting just for that. You are correct that it won't work in the intake pre-turbo. The boost solenoid SHOULD have a hose that goes to the engine and one that goes to your WG, but you say it is in the intake tract before the turbo so that definitely won't work for the WG. Originally, it had a line from the engine to the solenoid then out to the WG. Obviously someone has done some "fine" work before you got the car like most of us find.
No, properly set up you will be able to increase boost. Do you have a wide band guage to monitor air fuels? Or a way to tune?
Assuming my car has a stock ECU, would I need to buy a GM MAF cable or a non-EPROM socket conversion for ECM link? Also would I be correct in assuming that 850cc fuel injectors would be sufficient to provide fuel to accommodate a 20G turbo which flows 44lbs/min and around 20psi of boost? :hmm:
