Eagle vs. Manley crankshafts
RadDsm
1,679
24
Apr 28, 2008
Eugene, Oregon
So right now, I have 5 used cranks that need to be cut/ground .010 over. I don't want to run a cut crank, and I'm tired of wasting money buying used cranks that aren't good.
The Eagle crank was the first one I looked at (Eagle Forged 4340 Chromoly Crankshaft (88mm) - Modern Automotive Performance), but then I saw the Manley crank (Manley Forged Crankshaft (7 bolt DSM/Evo) - Modern Automotive Performance).
This crank will be going into my AWD DD. The Eagle seems like it would be a fine crank to use, but how about the Manley crank? The main difference in the crank that I saw is that the Manley crank is knife-edged. There isn't a whole lot of information on running knife-edged cranks in our cars (at least from what I could find).
What would be the trade offs from running the knife-edged crank, are there any negatives to it? Would I be sacrificing any torque due to the lack of rotating mass? I'm just trying to find out what the pros/cons would be.
Thanks to anyone who can help me with this decision.
Knife edging is to reduce rotating mass and increase efficiency (however little). It will rev a little quicker, but will make it harder to hold a steady idle.
