e85 fuel line sizing?
The 6an is fine for the return line. You could even run a 8an for fuel feed if you wanted to I dont think you need a 10an for fuel feed for that HP range. I am running a 8an for fuel feed and 6an for the return.
Geeze, I'm running stock fuel lines and filter and trapped 130.75mph in a 3395lb car on e85. why in the world would you need -10 for 600-750whp?
Like everyone has already mentioned you may rethink the size of line you plan on running because in this case bigger isn't always better. Unless you're running a mechanical fuel pump (or similar electric like a Weldon/Magnafuel) and/or dual banks of injectors that could utilize that size of fuel line I'd stick to -8AN lines both feed and return.
Even Weldons and Magnafuel pumps that can support over 1000hp have -8AN inlet/outlet on them.
Your checking account will thank you too since going to -10AN will nearly double the cost.
I'm running stock feed/return on E85 with an HTA76, single Walbro 450, 35psi, probably 550-600whp. Previously ran -8 feed and stock return on an S362 setup with twin 255s in-tank at 708whp.
Your current setup/fuel is exactly what I'm running. I've even had it up to 40psi peak.
