snowborder714
Moderator
- 16,188
- 465
- Oct 15, 2006
Mechanicsburg,
Pennsylvania
If you're trying to run 10:1, then yes, MAF Comp sliders need to be adjusted. You can see what you're really hitting (closer to 11:1) by viewing the logged wideband value.
Yes, you could have gained power, but you just went a little too far. To know if you truly gained power, you'd have to evaluate the logs (looking at airflow, injector duty, and some other values) at spool up with and without the timing advance.
Not quite sure why the IDC's went up.
You want to set the DA table to your target. This will display in AFRatioEst. You then adjust MAF Comp sliders to get the wideband line on top of the AFRatioEst line. You want to keep jumps between points on MAF Comp as minimal as possible and as smooth as possible.
