Does the 3" DSS Driveshaft fit the factory T-case?
stroh
84
5
Oct 17, 2002
Freeport, Illinois
Just wondering if it fits. I know the DSS 3.5" requires a built t-case. I'm assuming the 3" one will work for the factory t-case. Thanks.
Both can work with factory tcase or aftermarket big shaft. If you order it new, you can request factory yoke or aftermarket big shaft yoke for 300m tcase. If you buying used w/ aftermarket yoke, you can order factory yoke from DSS or Shep that fit 3" or 3.5" tcase.
Thanks for help. I was going to order it from extremepsi but I didn't see any option to choose from for the yoke.
How hard is it to change yolks on the DSS 950hp driveshaft from the factory yolk to the upgraded bigger yolk for the 300m tcase??
I would like to use the factory style yolk until my tcase breaks and then when I upgrade my tcase, Devo-2ning includes an upgraded bigger yolk along with the tcase so that i can install it on my DSS driveshaft when I get it back.... if its too hard or has been a pain in the ass for others then ill just order the DSS driveshaft from Devo-2ning at the same time I place my order for the built tcase so they can put the yolk on for me haha
I never did it on the DSS driveshaft, but I did do it on my stock driveshaft and it was, pretty easy the hardest thing is getting the Damn c clips out. After that it's just a matter of pushing out the bearings taking out the old yoke and putting in the new bearings and yoke.
You need a hydraulic press to not #### anything up.
