Did FIC make 1000cc injectors?
v8s_are_slow
2,825
280
Sep 30, 2002
Panama City, Florida
I ordered some 950cc injectors. On my receipt it says 1000cc and it's even engraved FIC 1000cc on the side. I was setting up the fuel injectors on the AEM EMS and in the drop down box it only goes to 950's. That's what I selected but still just makes me wonder. Thanks!
Scott
Yeah, they offer a set of 950cc and 1000cc injector.
#125-950 on the 950cc and #125-1000 on there 1000cc injectors.
Check out there website for more details.
K, I just looked at one of the injectors and on the side it says 125-1000. So guess it's a 1000. Now just wondering if I need to just set it to Fuel Injector Clinic 950cc (90lb) 2 ohm on the EMS and call it good. Cause that's as high as it goes for FIC.
Does AEM offer injector settings for any other brand 1000cc injector? You might see and then research to find out of injector firing felay is the same or not.....
You might need the injector drive box from AEM. This allows for low impedance and high impedence injectors.
I'm gonna have to throw up a post over on the AEM forums for this part because they don't have 1000cc injectors listed but in the instructions it says to use an injector from the same manufacturer and then right click on the fuel screen to change the injector size. When I do that, it tells me to select appropriate from Injector Setup Wizard to define battery offset curve. If I click the "ok" box, a configuration box pops up with nothing in it. Thanks for the input though.
AEM gets pretty confusing. I was looking into the Autronic system myself. A buddy of mine who makes race chips and tunes all systems available for most of the imports and some domestics was recommending it and I could get it through him at his dealer cost. Ill be posting more on this when i get to it. Just a brief intro to the Autronic. It features everything you would find on your AEM plus i know it features the injector drive box feature inside the unit so there is no need to purchase a box separately. It supposedly is much simpler than the AEM to use. It is considered by people who use it to be the only true plug and play. I think what makes it less attractive is it hasnt got the exposure as AEM has and its priced a few hundred dollars higher. We will see
