1000cc injectors
talonpower
52
Mar 31, 2003
Anyone have any experience with Venom Injectors??? I'm considering buying some Venom 1000cc injectors off a member of the board for 250US ... is this a good deal??? I only ask because I can't seem to find prices for these things anywhere ....
Thanks
Wes
How would you make them work??? I don't see DSMLink or a EMS in your profile. With a SAFC you won't be able to compensate for 1000cc injectors... It's just to much and you would likely never seen anything below 30* of timing advance... I got some 1000cc inj. from BR and I've yet to use them but I can program the ECU to use them... Also with large injectors like that it's likely that you won't be able to idle under 1K do to the very small amount of fuel needed and it is pretty hard to delive that small amount of fuel with large injectors..
If you plan on going with a EMS down the road get them... You would put them just behind your current 660's and use them for high boost aplication as you can control 8 injectors with most EMS's... Then you can still have a good idle and low end power with plenty of high end fuel delivery.... Or you could use them for water injection... Options are endless... :)
