Cylinder damage
RoadRunner2g
3
Dec 19, 2025
Ballwin, Missouri
I’m not sure if this is the right thread to be posting in, but it’s kinda cylinder head and block related. I melted a spark plug the other day, and my knowledge is quite minimal when it comes to internal engine damage. I was only able to take these two pictures before my borescope broke. There’s a ding that pushed the edge of the piston head out into the cylinder wall and started scratching the cylinder wall. There is also a bunch of dings all over the piston, and some damage to the edge of the cutout for the valve you can kinda see in the picture. I ran a quick compression test and it tested 150psi (Cyl 2) (Cyl 1 @155, 3 &155, 4 @140) I also noticed a decent bit of oil on top of piston 2 & 3. They both looked wet with some slight pooling in the valve cutouts on piston 2. I guess my question is how bad is this? I have a feeling the head needs to come if to be sure. If it is toast what would be the best way to go about fixing it? Complete rebuild? Or just replace the pistons and get the block sleeved?
First off, I feel your pain!! Sorry thats the view you got to see.
I'd 100% pull the head and evaluate damage from there.
Tough to tell from the pictures; but definitely something created havoc and it looks like an 'object' smashed around in there based on the impressions in the top of the piston.
You'll also want to look at any damage to combustion chamber/valves, depending on mileage it may make sense to refresh the head and maybe need a bunch of high spots taken down in one of the combustion chambers.
If there is cylinder damage, you'll have to tear it down and look at what is needed to overbore and clean up the damage.
Its all fixable! We're here with the advice to help get you through it.
Yea, the spark plug melted the electrode half off, and damn near all the porcelain from the plug is gone but the center electrode was completely intact.
Is there any threads that you can think of that go into detail about engine building and finding the right right combination of parts to build a strong engine? Haven’t had time to look. Do you also know of any machine shops I can trust with my 6 bolt? I also believe it’s bored .03 or .04 over already. I’m not sure if that prevents me from sleeving it or not. I’m not entirely sure if it’s already been sleeved or not either.
And lastly, what all would need to be replaced in order to pull the head off. Obviously the headgasket, and I should replace the timing belt too since it’s 15+ years old.
I am trying to figure out what would go into the cylinder to do that and not have any other issues 🤔
