turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
Here's a few snaps of some stuff i do on 1/5th scale RC car engines (basically highly modded weed eater engines)
THis is a +3 mm longer connecting rod to of course, change the rod ratio and allow the engine to make more power and rev out freely up top.. The common ones i do are +3 and +5 but there's not much use for the +5 IMO unless you have one of the custom machined reed case induction cases (like the one i have
) or ou are using nitrous to force feed the engine.. I am cutting these rods from 2 materials depending on requirements.. This one is 4140 Chro-Moly, and sometimes i'll make them from 440C SS (but that stuff EATS end mills even in anealed state)
I've made some aluminum ones for these4 engines but turning 21k + RPM at peak revs puts some major wear them pretty fast, thebearing holes will oval out since you can't leave enough material to prevent it given the size constraints yuou have to work within
Anyway, though tyou guys might get a kick out of this.. I still neet to thin out the middle, add oiling ports for the bearings and micropolish the last .0005" from each bearing journal to complete this..
In case you're wondering the price to do this is about 285 bucks to 300 if you ship me a complete engine and i tear it down and rebuild and port it for the longer rods.. it's really a lot of work since you have to split the crank, then re-pin ad align it (about 2 hours to do that alone) but man these engine RIP once you've got reed case induction and a loger rod.. eventhe piston port models now being offered commercially with long rods are making just about 7hp ( a tad over) on a 30.5cc engine.... (and mods since htis isn't even DSM related let me knwo if i still should mention the price) but i'm not here trying to sell these
The "finished" looking one is a factory rod that is 50mm from journal center to journal center.. this one i'm making is 53m at the same measurement
) or ou are using nitrous to force feed the engine.. I am cutting these rods from 2 materials depending on requirements.. This one is 4140 Chro-Moly, and sometimes i'll make them from 440C SS (but that stuff EATS end mills even in anealed state)I've made some aluminum ones for these4 engines but turning 21k + RPM at peak revs puts some major wear them pretty fast, thebearing holes will oval out since you can't leave enough material to prevent it given the size constraints yuou have to work within
