2 Small Aluminum Widgets
turboglenn
6,375
123
Nov 5, 2007
RIpley, West Virginia
Here's a couple pics of some more parts i made to go on that CRX, the ones on there were functioning but the first piece (throttle cable bracket) wouldn't face the cable straight down, it was at an angle that looked funky. So, I made this piece to correct it
In the morning when there's no one sleeping i'll fire up the die grinder with a scotchbrite pad on it and knock the sharp edges off along with the rest of the Dykem
these were also taken with my cell phone
This is a piece i made because i thought the little piece holding the top of the radiator was just dead ugly (and you can see in this pic..it is LOL )
here's the side view of that same piece, only thing left it to bore the small hole in the top to 24mm, but again that's a louder process i'd rather do when no one here is alseep
hope you like them as much as i do, there's more time in them then what they are worth and i free handed these, just eyeballing where i needed to be, it's funny how accurate you can become to get two things within the same size down to .5mm after many years of machining (that's usually where i stop visually judging and measure on important pieces)
Well, not trying to bump this or nothing, but i wanted to update that the throttle cable bracket worked out perfect! (i didn't have the setup here to build it from, only went off memory) and a lot of people like the radiator bracket (could have been shorter in height and from the radiator peg to the mounting on the radiator support)
But i know how to improve the one second go around, and the cable bracket i just need to make more of as i hear this is really commoin on hondas with SMIM's
dont' worry, i'm going to make some purdy aluminumbrackets for my own DSM here soon (wanted em pretty bad for a while now) so i'll post up when i do, or you can pm me or i'll pm you about them if i need to get to them early or anything
but that's something been on the burner for a while cause i'm sick of those black metal looking stockers :p
