Cruise Control wont set
SoNew
179
Mar 5, 2011
Madison, Wisconsin
Tried searching for a similar problem but couldnt find one. My cruise worked yesterday and I've done nothing under the hood since then (believe it or not) haha. Today I was driving home i clicked the cruise on button and it lit up but when i went to push the lever down to set it it never set. I held it down, tapped it, pulled the clutch pedal up (didnt move). I cant figure it out. WHERE IS THE FUSE!? I checked under the hood and dash and cant seem to find it. please help I have a 15 hour drive ahead of me on monday!!!:banghead::notgood:
Make sure that the clutch switch is adjusted right. The one that it rests against when the clutch is not pressed down. My CC never worked and I had to adjust the switch for the Clutch Cut for ecmlink and it fixed the cc. Sure when you pulled it up it may not have stuck right, Maybe try that. If not then also check the brake switch..
Resolved:thumb: The clutch pedal has that little metal piece that sticks out to engage the switch at the top, In the middle of that piece there is a little hole where a tiny plastic piece is SUPPOSE to go. I found mine on the floor mat, a thumb tack a few cuss words and some epoxy later and CRUISE WORKS!:applause:
