C'LO
- 147
- 18
- Sep 9, 2007
Haverhill,
Massachusetts
I know there are a ton of threads on here about this, it plagues the DSM and Evo community.
First of all i know everyone just runs 2 fittings from the valve cover and either vents it, or reroutes it to a vacuum source (usually pre turbo), but does anyone actually care if the pressure is gone and vacuum is not present? So I've read the bible at evom that everyone with a single question there gets referred to http://goo.gl/LdMDqn I'm currently in page 56
, but there is no exact answer. Now they are getting into external air pumps, which I'm sure works great but a bit much, which leads me to the set up that Jacks Transmission did http://goo.gl/ls5ng8 which appears to be 3 huge lines from the cam cover directly to the intake, which leads me to think 2 lines can pull less, and with the lines being longer maybe they'll be pulling less. But I don't know as my engine will be having a different set up completely, and just in case I shall possibly have a valve cover made.
Just seeing if anyone else was curious enough to see if they have gotten rid of all pressure or don't care, or just have a completely different set up and have success?
, but there is no exact answer. Now they are getting into external air pumps, which I'm sure works great but a bit much, which leads me to the set up that Jacks Transmission did http://goo.gl/ls5ng8 which appears to be 3 huge lines from the cam cover directly to the intake, which leads me to think 2 lines can pull less, and with the lines being longer maybe they'll be pulling less. But I don't know as my engine will be having a different set up completely, and just in case I shall possibly have a valve cover made. Just seeing if anyone else was curious enough to see if they have gotten rid of all pressure or don't care, or just have a completely different set up and have success?
