1G Oil pressure
Dsmpagan
126
5
Oct 29, 2013
Wolcott, Connecticut
Oil pressure is a little funky and I want to know if it’s the gauge or not. Hold pretty steady at 60-75lbs in the gauge at idle. It’s an auto meter gauge. Bounces around a tiny bit but if u rev it pressure goes down to between 0-25lbs.
Is there a way to check it with ECMLink? If you how do you add it to watch it live?
Thanks for the advice.
If you still have the oil pressure sender hooked up for the dash you should be able to watch that one. Even tho it doesn't give exact pressure you still should see it drop some.
If it's a digital gauge I would guess the sender is bad and going out of range when the pressure goes up as you rev it. If it's a mechanical gauge I would be a little more concerned that oil pressure is the actual issue but it would still be pretty odd. The only way you could really loose pressure as RPM goes up is if the bypass in the oil filter housing is getting stuck open
