Coolant tubes, delete everything.
Stainless? Should make some 2G non turbo ones with no ports for a turbo.
If you run the right manifold you don't have to dent it. Mine clears by an inch. But its a custom manifold made by myself for a holset.
The 4g64 NT water pipe DOES NOT work on a 4g63 2g, I promise. Despite all of the threads/info out there saying that a 4g64 N/T water pipe fits, it truly doesn't as I trusted the multiple threads out there saying that it worked and I bought one. It was only AFTER I modified it and installed it into the water pump and bolted it to the block did I realize that in bends the wrong way at the t-stat housing. :ohdamn:
Here's a picture of the two water pipes (my two water pipes) showing the difference, notice that the brackets that bolt up to the block are both oriented the same way but the stock 4g63t water pipe (top) bends back around the head while the N/T 4g64 pipe (bottom) doesn't bend?
I know they dont fit silly billy. I just asked if he would make the non turbo pipe with no turbo lines aswell, (as in 2G 4G63 non turbo!) Lol same pipe and just no turbo ports for coolant. Thata the pipe i was reffering to
Well, there's no N/T 4g63 2g over in the states so grab all of those water pipes that you can before you move to Flo-Rida.
Roger that
