all black 4G63
5+ Year Contributor
278
51
Aug 5, 2019
Chicago, Illinois
(Long thread warning )
So I wanted to post this as more of an informational/discussion thread based on coolant pressure monitoring on a 6 bolt motor. I’m doing this because I couldn’t seem to find any solid “answers” or info on-line other than researching fluid dynamics and running into the issues I was having. “I’m sorry if this is blatantly obvious to everyone already as i was second guessing myself.”
So when it comes to monitoring coolant pressure in your engine we do this to verify how much boost is “too much” as the cylinder head may lift and combustion pressures may push into the coolant chamber which at that point can damages heads gaskets and more.
So I’m running a non O-ringed block with EVO MLS and L-19 studs on a PTE 62/66, e85 @35 psi. Haltech 1500 NSP. Makes little over 600hp
I started monitoring coolant pressure at the port designated for the IPC coolant gauge on the lower side of the thermostat housing (1/8” bspt). I was running the Haltech Bosch coolant temp/pressure sensor. I have no heater core or coolant running to the throttle body.
During warm up-idle everything was normal, low coolant pressure and temp. At around 190F ~1000 rpm pressure was 13-14psi and the t-stat would open. However, if I rev up the motor (5000 RPM +) coolant pressure would easily reach 40-50psi! This was crazy because I thought I had a severely damaged motor, but I would never push coolant or overheat.. also during hard 35 psi pulls I would also reach 40-50psi.
I began to think having the Bosch sensor mounted on the motor (t-stat housing) was vibrating throwing the readings off. So I bought the Haltech 150psi TI pressure sensor and remotely mounted it on the fire wall even using rubber washers as a precaution. This made absolutely no difference, I would still reach 40-50 psi reving at an idle.
At this point I was starting to think that I didn’t fully understand what was going on so I had to dig further. I knew there was no way I had that bad of a motor especially since the gasket was fairly new and compression was good and I didn’t loose coolant or overheat.
Looking on-line learning that everyone would say coolant pressure shouldn’t go too far over cap pressure spec (.9 Bar 13 psi) I thought maybe I didn’t fully understand the cooling system of these 4G’s..
Basically during warm up (t-stat) closed the coolant obviously needs to flow and is bypassing the radiator (like normal bypass). If you look at a 6 bolt block there are two ports at the water pump mount this would technically be where “bypass” would take place. Obviously when the system is in “bypass” mode (t-stat) closed the centrifugal pump is producing pressure and flow pushing coolant through the block and head. While the t-stat is closed the coolant circulates back to the pump from one of the two ports at the pump mount on the block. Since the centrifugal pump design is to disperse fluid on the outside of the impellers the pressure will constantly increase as the RPMs increase. Stock DSM pumps produce max. 140 Lit. @ 6000 rpm. That’s a lot if you think about it. So how does this work? How could I see 40-50 psi if the system is supposed to be under 13psi.
Well it’s not. If you use the laws of fluid dynamics and Bernoulli’s principle that the pressure of a flowing liquid will change based on the change in the diameter or area of a pipe. Basically, the area “pre t-stat” is larger then “post t-stat (radiator side)”. So naturally what will happen when the pressure behind the t-stat is high and is building it will drop when the t-stat opens. (this is because the area behind the cap is larger then the diameter of the piping on the rad side). This is the same as holding your thumb over the end of a garden hose. The flow will not change (Bernoulli’s principle) but the pressure will and in this case it drops.
Centrifugal pumps can actually build so much pressure that when the cooling system is in bypass and if there’s not enough of fluid at the center, the pump can cavitate and produce and area of air. You may notice this if you boost hard with slightly low coolant levels you will see your coolant temp rise suddenly then drop when off the throttle.
So based on this info I moved the coolant pressure sensor to the port where the AC temp sensor would’ve normally been (see photo). Now at an idle and during hard boost I barely reach over 15psi.
I hope this will be the correct way to monitor coolant pressure as I would think if the area past the t-stat would build under boost this would be an accurate way to tell if combustion pressure is leaking in.
Please let me know your thought or if I’m just crazy and over thinking this but, hey at least I know my motor and head gasket are good I guess.
I have a similar setup to you, albeit on a Fueltech FT550.
I started monitoring coolant pressure when I made the swap over to FT last year, I have the sensor mounted in the bottom housing right beside the temp sensor, with no thermostat. Last year I was on an OEM MLS gasket with copper o-rings, car made 731hp on the dyno on 35 psi. I turned it up to 42 at the track so I'd estimate 800ish.
Sitting idle, warmed up it would sit at 8-9 psi. On the dyno it reached 16 psi with a Stant 13 psi cap.
On a gentle pass down the track, 35 psi, granny shifting and only running a 10.32 ET, it peaked around 17 psi.
Later on with the car turned up to 42 psi, running a 9.63, it peaked around 35 psi. I was a little concerned but it showed no signs of issues.
That was the end of last year so when I tore it down for maintenance over the winter, there were 2 small black traces on the MLS gasket showing signs of combustion passing the o-rings but nothing damaged.
Over the winter I changed over to the SCE vulcan gasket to try it out, head torqued down to 105ft-lbs with L19 studs and ARP insert washers in the head as well as a Chase bays 20 psi rad cap. Now after weekend, the car made its first pass down the track this year with the new setup, tickled 40 psi of boost and coolant pressure touched 38 psi in 4th but no signs of any issue or pushing coolant.
So I have no other experience with coolant pressure so I'm guessing this is normal, I'll keep monitoring and maybe one day I'll find out what an actual issue looks like LOL. I've ballooned a radiator before so when it goes real bad, I know it's way more than 40 psi.
Later on with the car turned up to 42 psi, running a 9.63, it peaked around 35 psi. I was a little concerned but it showed no signs off issues.
Over the winter I changed over to the SCE Vulcan gasket to try it out, head torqued down to 105ft-lbs with L19 studs and ARP insert washers in the head as well as a Chase bays 20 psi rad cap. Now after weekend, the car made its first pass down the track this year with the new setup, tickled 40 psi of boost and coolant pressure touched 38 psi in 4th but no signs of any issue or pushing coolant.
Yeah I see. The fact that you don’t run a t-stat would make sense why didn’t initially run high coolant pressure, (there is no pressure drop or divide in the system.
I'm wondering if you rev it up to like 8000 rpm at a stand still “or whatever you rev to when you hit 40+ boost and see if the coolant pressure rises to around ~35psi. If it does then your simply seeing the result of the centrifugal pump pushing massive amount of coolant due to the high rpm and your head is probably sealed just fine.
Hey this is great info thank you for sharing! especially the fact that you found a suspected anomaly with your head gasket, but even after replacement it made little to no difference in your coolant pressure spikes.
I have an update as well:
I now make 756hp running 39psi. On the dyno my coolant pressure will not spike however intermittently when doing mild pulls on the street it will.
I have removed my remotely mounted sensor via the hose in the above photo to directly on the thermostat housing. This made no difference either. I’m using the Haltech 150psi sensor and see no issues with anything with it or any related wiring. I also don’t push coolant so, I’m going to have to say that this is just expected. Please let me know if you have any updates. thanks!
I have removed my remotely mounted sensor via the hose in the above photo to directly on the thermostat housing. This made no difference either. I’m using the Haltech 150psi sensor and see no issues with anything with it or any related wiring. I also don’t push coolant so, I’m going to have to say that this is just expected…Please let me know if you have any updates. thanks!
I have an update from that past situation, later on in August of 2024 on a low 9 second pass the coolant pressure spiked to 40+ psi, upon further inspection after seeing the oil turn to a milkshake, turns out I cracked the block. Perhaps it had been cracked for a while, just not that bad. I built a new block and no more spiking coolant pressure.
oh no!!!!! this is what I fear!! so with this crack you were experiencing an intermittent spike? I would imagine the coolant pressure would build consistently during pulls?
At first it didn't seem like much of a spike but it just progressively seemed to get worse, probably as the crack grew. The funny thing is the car never really showed any issue running wise.
so you mentioned seeing milky oil indicating the coolant/oil mix. was this milky oil vary apparent (obvious)? Like was it bad observed at the oil cap? also could I ask what pressure sensor you were using and where was it located?
It's a 0-150 pressure sensor from Lowdollar Motorsports, tapped into the t-stat housing.
There's no mistaking the milkshake LOL
1st pic is with a 16psi radiator cap, 2nd is with a stock radiator cap. Mechanical water pump, open blades (oem). Sensor is also in the lower tstat housing right next to the temp sensor.
So you run the sensor in the lower t-stat housing? I has mine there and could just rev the engine up and would see like 40-50psi. Are you running a t-stat in that motor?
I must have something very strange going on. I borescope the cylinders and everting looks great, the oil is very clean, I don’t push coolant, so unless I have a bad sensor or a crazy w/p idk
160 Tstat in the housing, engine warmed up.
Well damn…I’m running a stock “stant” t-stat, it has a 22mm opening I’m wondering if this is the issue. I’m going to change it with a 180 with 34mm opening and see
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
