9 T GSX
- 203
- 38
- Jan 19, 2008
St.Pete,
Florida
The billet main caps are unnecessary, and only involve alot more machining to be installed on the engine. Save your money and machine the stock main caps. I don't think I have ever heard of the stock 4G63 main caps failing.
If you are going to be running a 6-bolt, I would recommend looking into the Kiggly main girdle for extra support.
If you are running a 7-bolt, then it is only necessary to clearance the stock main girdle to fit the rods (on a 2.0L; but you will need to still clearance the rest of the block to clear the rod stroke; especially if on a 100mm crank).
for a 2.0 7bolt build do you have to grind the bottom of the cylinders to clear aluminum rods? got any pics?
