1G Compression test now no start
enriquez2000
2,411
1,020
Oct 5, 2014
fort collins, Colorado
Did a compression test and numbers were low as expected(car still ran ok).. tried to start the car after checking all 4 cylinders and it acts like its not getting gas stumbling and thumping at 500rpm with foot at wot and dies as soon as i let off.. starter fluid seems tobget it to start a bit better but eventually it gets used and goes back to thumping.
Used link to verify fuel pressure to the rail. Checked injector pack resistance and it was good. Coils are good and did a firewall spark test to verify spark.
Not sure what else to check. The only thing i did was unplug cas to do the test and plugged it right back on after and now this.
Give the wires a tug. It should be obvious if its broken. Will the car start at all anymore? After cranking are the plugs wet? Was there anything else you did while doing the compression test? Check fluids? Also chekl out the coolant temp sensor on the thermostat housing. If the connector came off or wires broke it thinks its -40 degrees.
This is deff a weird problem.
Plugs are not wet.. it cranks and stumbles a bit but kind of acts like no gas. It tends to do that with e85 but after 2 or 3 tries used to fire up. Starter fluid in TB makes it attempt to start but as soon as it runs out car dies.
CT sensor is good reads 62*
Fluids are good
I checked the isc and its good
Fuel pressure is 43psi to rail
noid light shows injectors getting signal
I swapped to cop to verify coils werent the issue and put in fresh plugs(no change)
Verified 12v at cas and ground(still need to check tdc and other wire continuity to the ecu)
Timing marks line up
I also verified that injectors arent stuck by triggering them manually
I really have no clue what else to do. If it isnt continuity on cas im effed unless somehow the power transitor is the culprit but id assume no spark then.
If you have spark cas is working.
^This. Same thing for fuel. If you have spark and fuel, the CAS is probably functioning as it should.
Your CT sensor reads 62*, is 62* currently ambient temp where you are?
I'm leaning toward maybe an ECU issue. I'd say pull the ECU and check the board for damage, leaking caps, or possibly a burned driver.
Yes its 62 out.. i can pull ecu. Was just gone over by ecmtuning about a year ago but I guess you never know
Since it kind of stumbles when you spray starting fluid try adjusting your cold start fuel perecentage in dsmlink. Im not too good with e85 but i know it needs a lot more fuel to start. Try increasing the percentages about 10%.
How's the back side look?
My Miata's ecu looked perfect when i looked at it. Ended up being the only problem. Swapped another in and she's been running ever since. The old ecu would let the car start but then it would just die no matter what I tried. Got another ecu you can try? If you don't hit me up I think I have one you could use to try.
I have a stock one but with 1200cc injectors im not sure itll help
Swap some stock 450's in. I have those too if you might need to test. Hey didn't you say the isc or something was getting really hot? Could be a sign there's a issue with the ecu.
