Compression numbers stroker vs stock
no im not talking about compression ratio talking about psi when doing compression check
Well didn't get to pick compression ratio. Was a 2.3 stroker kit from slowboy. 600 horse kit with manley pistons anybody know what that would be
That's a very vague, question. Every engine is different first off. Also number will depend on more than just what pistons you run. It will also be determined by what your deck height is on your block, head, and finally how thick of a head gasket you will run. Since its a vague questions I'm going to guess its going to be around 150 psi.
The head was decked not sure how much was taken off its a.0.50 mm gasket tho I know that
Well I don't know but I have 10:1 wisecos and mine checked out at 180-185 across all 4 don't remember exact numbers but they were all within 0-5 difference. Haven't had to check it lately though.
12 years later but I'll tell you, I have a 2.3 with stock bore 85mm 100mm Eagle crank Wisco pistons, Eagle H beam rods, stock bore, stainless valves, and GSC S2 cams.
I'm 135psi across all 4 pistons.
Running FP black at 40psi.
I have roughly 30 miles on the build.
What cams and how much overlap. This can greatly effect the cranking compression when there is a lot of overlap. I can swing my results over 40 psi depending on how i have my cam gears adjusted with GSC S2 cams. I check leak down when breaking in my motors to tell when rings are seated and not the compression test. I have multiple 10:1 motors that depending on cams and overlap test anywhere cold from 150-225.
My 2.3 2g has somewhere around 225 psi with the stock cams and 10.5:1 pistons.
The compression test number would depend on many factors, such as static compression, cylinder and combustion chamber sealing condition, cam profile, valve/cam timing you set, battery health etc. So it doesn't matter if it's stroker or stock stroke since it's already calculated in the static compression.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
