Clutch Pedal Adjustment
fwdturbobov1996
1,504
8
Feb 27, 2004
Blue Springs, Missouri
Ok exactly how do i do this. I see the bolt, well i can feel it. I have the wrench. Do i tighten and loosten it to make it stiffer? My clutch is engaging right on the floor and its annoying as shit. Well it gets really stiff right at the floor. So just tighten and loosten it? Which way brings the pedal up off the floor?
loosen the locking nut and screw the rod out ( towards the firewall) to raise the engagement point.
you might have to use a pair of pliers to back the rod out though.
Make sure you apply the pliers to the part that's squared, not threaded to insure you don't screw up the threads. And each full rotation does make a big difference, make sure you tighten the locking nut also so it doesn't come out of adjustment.
It will be right past the thread. There is a part where two of the sides are flat instead of curved, so you can use a wrench or pliers to grab the rod and turn. Just take your hand and feel for it.
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 1g WTB: 4 Bolt Axle Cups.
    Looking for a set if 4 bolt axle cups for a 1g. Located in Canada.
    • blaster1812
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
