clutch help please!!!!!!!
gst-negro
Dec 17, 2006
snellville, Georgia
HI GUYS, I HAVE A 97 GST AND THE CLUTCH PEDAL STICKS DOW ON THE FLOOR AND I JUST HAD THE CLUTCH CHANGED AND THE SLAVE CILYNDER. I KNOW THAT THIS QUESTION HAS BEEN ASKED MANY TIMES BEFORE BUT I JUST CAN'T GET IT FIX ANY HELP WOULD BE GREAT!!!!!!!!!!!!!!!
THANK YOU VERY MUCH:thumb:
I Will Do What You Told Me,
1- Check For Leaks
1- Check Master
3- Check Firewall
4- Check Lines
5- Bleed The System
Am I Missing Something????
thats pretty much it, moniter the fluid level, if its not dropping any then that means there is air in th elines, which means you just have to bleed it more, other than that look for obvious leaks. good luck.
Thank You Very Much Man I Will Let You Know What Happens Take Care And Tankyou Again!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
