Clutch engagement point moves.
jakk220
1,320
320
Nov 13, 2010
Akron, Ohio
Just replaced the master cylinder recently on my 2g and the clutch will occasionally engage right off the floor. Normally its at the mid way point as it should be. I don't believe this is pump up because it doesn't change pedal pressure. I've bled the system 3 times now so I don't think there's any air. It will engage off the floor maybe every 30 times or so that I push the clutch in. Any ideas why this is? Could it be there's still air in the system?
dude, i just had this same problem and posted a thread.
adjust your master cylinder rod.
if you need help pm me,
or just youtube.com "jacks transmission clutch adjustment.
seriously, it'll fix your problem. :rocks:
problems:
-go into gear fine when car is off, but hard when started??
-driving down the road, the clutch has like almost no resistance sometimes? then once u pump it, itll be normal??
