Clutch bleeding problem
b00stedtalon2
1,084
621
Dec 19, 2005
Detroit, Michigan
I just put on my new SBR stainless steel braided clutch line that goes from the master cylinder straight to the slave. Went to bleed the clutch and the fluid doesn't want too flow to the slave. I pumped the clutch pedal back and forth over 100 times with the slave open and shut. Nothing seems to be clogged and the clutch fluid reservoir is full; and stays full as well.
Any Ideas?
