VBR_DSM
- 55
- 39
- Sep 20, 2023
Las Vegas,
Nevada
I thought it would be a good idea to drop the oil pan and fix a couple of small leaks while my power steering system and suspension are out of the car for service.
I found the debris shown in the pictures attached inside of my oil pan. After reading a few threads it sounds like the big brown material are turbo bearing fragments likely from a blown turbo. Sounds like this isn’t a concern for the engine, especially since it was running fine before dropping the pan. Turbo seemed to be working fine as well. There are also some RTV chunks which don’t sound concerning.
However, I am concerned with the silver metal chunks being spun rod bearing material. Please note that these pieces are NOT magnetic. There was also a small amount of silver glitter in the oil left over at the bottom of the pan shown in the picture. Never saw glitter in any of my oil changes before. No knock or low oil pressure that I’ve noticed.
Can you guys please help confirming that the brown material are turbo bits and let me know your thoughts on the grey metal chunks?
Does anything jump out at anyone from the pictures of the bottom end?
