Archer Fabrications
- 9,719
- 706
- May 9, 2011
Scottsdale,
Arizona
hi guys, I'm working on deleting unused plugs but had a few plug identification questions on the fuze box harness and the engine harness here it goes
#1
There is a ser of plugs that come off the driver side it's the first set after the Abs Plug that goes to the break itself, and before th abs computer plug (on the 99) the set I'm pointing to is a brown plug. Blck plug, and two grounds, and has a grommit that goes theough the fender, the single plug on the left is the driver side turn signal amber. The only thing that was in use was the grounds, I'd like to remove it all if it won't hurt anything, and I'd like to know what it used to go to. (SOLVED!!!!! Brown AC, black main horn, grounds I'll assume are for AC, these are now deleted)
#2Next is this single plug, 2 wire connector i dont think it's fog lights. But it comes out of the harness right next to the main driver headlight plug. (SOLVED EVAP PURGE SOLINOID PLUG)
#3 moving down tword the fuze box ive cut out the oil dummy light and oem oil sender plugs... Hope thats cool, i habe an aem oil psi gauge..
#4 by the pssenger fenderwell there is a box with a ring terminal before the harnness goes back into the pssenger side fender well. What is this to?
Other the. That on this fuze box harness ive removed fog light plugs, and some other random connectors that were not in use and were tied up around the harness
So this leaves me with only the following plugs on the fuze box harness if i delete the above, let me know if this sounds right (trying to go minimalistic while keeping basic functions of lights and street legalness)
From driver side fender well plug to the pssenger side fender well plug:
Driver side turn light plug
Driver side Side marker light plug
Abs computer plug (will remove)
Main driver head light plug
Driver side rad fan plug
Alternator power and ground
-Long section that runs across rad support-
Passenger rad fan plug
Fuze box itself and connection to engine harness
Main passenger headlight
Pssenger side marker
Pssenger turb signal plug
-then through firewall plug.
Thats the fuze box harness only, on to the engine harness.
Starting where the engine harness connects to the fuze box harness, right next to the maf plug i have two unknown plugs (SOLVED small plug is for boost control solinoid, orange plug is for cruise switch)
#1
#2
By the coolant temp sensor thre three plugs two were unhsed (one my that my thumb is on I'm sure is front 02 sensor unused the ones above it in the below pic is the coolant temp sensor plugs) and another was used but i dont know what it went to. Please identify black plug.
(SOLVED!! Trans speed sensor 3 wire, and 1 wire starter solinoid black)
Last one #3 is by the injectors and coil pack plug. These are at the very end of the harness, I'm guessing it's AC stuff and was t used and can be deleted? One looks the same as the coil pack plug, the other looks the same as the unknown fize box plug #2 I'd appreciate all identification thanks in advance!
Also, i do have a chiltons manual but I'm not good at all with wiring diagrams
#1
#1
#2
i opted not to de pin because who has time for thay haha I'm chopping connectors, going to unloom and remove the cut wires, then I'll re loom and electrical tape and extend wires needed with the wires i just cut.
