Changed timing belt now have vibration
dwj119
Jul 5, 2005
Etters, Pennsylvania
My friend who is a mechanic (not too familiar with dsm motors) changed my timing belt for me because the belt slipped and my car stalled. I lucked out, no valve damage :) ( I was at idle) Now I have some vibration (pretty bad) when I reach 3000 RPM. Can anybody please point me in the right direction as to where to start investigating the cause of the vibration? Thanks.
1990 Eagle Talon (non turbo) - Harrisburg area
Your rear balance shaft is out of phase. Line everything up to TDC, take the timing belt back off, and rotate the oil pump another 360*.
This is probably a stupid question but what does TDC mean? I will be relaying this message to an actual mechanic (aka no myself) ROFL
Out of phase meaning it should be removed ?
nevermind my dumba*s question I just re read the vfaq
NOTE: Crankshaft may need to be rotated up to six turns before all sprockets are properly aligned and the rear balance shaft is in phase, due to the oil pump-to balance shaft gear ratio.
Thanks for the help.
One more question!!! Will I hurt the car by driving it like this for a couple days until I can get it to the mechanic to get it fixed?
I wouldn't drive it - all those vibrations could jar something loose or do worse. If I DID drive it, I'd keep it under the 3k mark, since that's where it starts vibrating badly.
Most people agree that no real damage will result. I drove mine for over a year that way.
I think you mean rotate it 180*. If you rotate something 360*, it's in the exact same position as when you started, which wouldn't make his problem go away.
2:1 balance shaft to oil pump. The drive sprocket will go 360°. Mine was out-of-phase by the dealer. :rolleyes:
I had the exact same thing happen to me when I got my timing belt changed right before I went on a trip to Oklahoma. I had no choice but to go ahead and drive it the way it was, then take it back to them to get it fixed. I had no problems with it on the trip. I think that you should be fine until your friend can get it fixed.
Good luck!
:thumb:
there is a bolt in the back of the block. if you remove tis and can stick a screwdriver all the way in your in phase if not rotate until you can. simplest way to check it.
Gravity during install is the simplest way, but the rod-thru-the-hole might be the most positive.
