CAS problems?
David Boyd
Nov 15, 2016
hoanker, Virginia
Okay guys so I have a 95 eclipse gst with a 6bolt 1990 swap. Just rebuilt the whole bottom end and got the motor back in and it won't idle. It will idle about 10 seconds then shut off. The car does fine at WOT. I'm thinking it could be the CAS timing because I'm not getting any codes on my code scanner for a bad CAS? Also the car will build rpms on its own. Any ideas?
Im really confused, you think its the CAS because there is not a code triggered for it?
What about intake leaks? ISC/IAC operating? I have never had that issue with the CAS. Is there something else that is giving you that feeling?
