Car won't start!
davidharvey14
36
Nov 23, 2010
brimield, Ohio
so i my car wont turn over changed the relay in the fuse box nothing, had starter tested n battery .. perfectly fine ... ground wires r right ... still nothing all the dash lights come one and do not dim when i try to turn the engine over everything is done right im stuck and i need this car done by next week becuz i start my job ### help me text me or cal me or ne thing 330 212 6107
If it is an automatic, try putting it in neutral to start it. If it is a manual, check to make sure the clutch safety switch is working right. Double, no triple check the ground. That is an all important part that most people overlook. Does the car have a security system on it?
grounds r correct no it does not have a security system on it it is a five speed n clutch saftey switch is on
I had the same problem with mine, it was the starter relay under the dash (behind the radio). You can use a wire to connect the wires to see if that is the problem.
you say need it done. Does that mean u weee working on it? I had a problem like that a week or so ago after rebuilding motor. When i put tranny and block back together didnt have the spacer plate in, i didnt realize how important that lil peice if sheet metal was. You could always try that.
