turtlebain
- 447
- 28
- May 16, 2012
Rochester,
New York
This is where it lies - car is in the air. Both front & rear tires spin freely causing the opposing tire to spin in the opposite direction (which as I understand it just means it's spinning spider gears all around inside front and rear differentials.)
Fresh Engine build
Fresh Transmission build OEM besides 4-spider center diff & performance shimming.
New clutch, Clutch slave not hooked up
Engine, Transmission, Transfer case not even oiled yet (besides assembly lubes)
Gears all change with about the same amount of resistance using levers on the transmission itself not shift cables doubt it's a broken shift fork, I have done nothing to break it yet.
One thing I can say I hooked up the shifter cable bracket opposite, went to test out the shifter from inside the car. It felt wrong from inside the car. That's when I realized I put it on backwards. Then put it back on the right direction.
When you attempt to spin the drive shaft it sounds like there is a tiny bit of play then it's contacting metal in both directions.
Suggestions?
Fresh Engine build
Suggestions?
