steve
DSM Wiseman
- 17,443
- 4,142
- Feb 3, 2002
St. Charles,
Illinois
Without a label on the log it's hard to know what your trying to show us in each.
Please plug your TPS back in and add ISC Position to the variables you're capturing.
Under the DTC tab deselect the Cat efficiency/O2 checkbox so you don't throw O2 Heater DTC's from your wideband using the front O2 wiring.
Your target idle speed is 850rpm. It doesn't look like you're anywhere close to that so look for air leaks and make sure your BOV is connected to the intake pipe. Based on your profile you should be able to idle at 850.
You have changes to both the Global deadtime factor and InjBatteryAdj Direct Access table. These are additive so you have almost twice the deadtime at 12v. I'm not sure that is what you want. Consider resetting the InjBatteryAdj Direct Access table
If you have a voltmeter measure the Key Off Engine Off voltage at the B+ stud of the alternator. If it's not the same as your battery voltage then the alternator fuse is popped.
Generator FR terminal circuit malfunction indicates a connection issue either internal to the alternator or with the 4 wire connector that plugs into the alternator.
