NTRCOOL
- 0
- Apr 10, 2002
OVERHEATING? The issues and their solutions have remained the same- either you don't have enough cool air reaching the rad, there's a cooling system obstruction which is preventing coolant from circulating, or your head gasket has failed and is allowing coolant to be consumed or pushed away from the engine.
Discuss all possible overheating problems and solutions here.
OK,
I just left my house to go over to my GF's,and happen to look down and see my needle right before the red mark. This just happened out of nowhere. I stop the car as quickly as i can, and pour in some coolant(Coolant a little low). Still same thing. Welp im in the middle of the road, and HAD to get it home. Im only 5 min from my house. I decided to try and make it(I really had no other choice). Welp I drive no faster than 20mph, and the temp needle is BARELY into the red the whole way.And occasionaly to the left of it. Am I ok?? Do ya think any damage was done?? And im thinking either thermostat, or water pump. For each of those, whats a round about $$ figure to get replaced?? Any info you have would be GREATLY appreciated!
OK,
jackass about it. I read for an hour before I posted. Saw several overheating issues. None that looked like mine regarding all the parts I have replaced and still having the issue. So I thought if I posted and someone more intelligent about cars then myself could help then great. The car will be dropped back off at the shop today for them to have a look after I get out of work. No leak from the heater core but I was thinking it may be clogged from what I read and that maybe it is causing the issue. But me being curious and frustrated with the issue I looked to the board for some help. Thanks pal. Much.....
a peace e a ted
