Resolved CAR JUMPED CONFIRMED!!!
SNAKE_15
571
48
Aug 28, 2012
Bakersfield, California
I'm lost right now, but here is the story. I got my ac recharged yesterday and I drove home fine. I then took my car to work and everything still ran fine. I came home, washed my car, turned it on, but it bogged every time I start it. I checked my maf and looked for any vacuum leaks but nothing. I checked this morning to start my car and the same thing happened. My car only has 84,000 miles. My car always had this camming idle, but I never checked if it had cams. When driving, my car would would die when I put it in neutral while my ac was on. Probably because it dropped the rpm too low and it couldn't recover. This is the first time I'm experiencing this problem.
What is off by a tooth? Crank at tdc and intake line up but exhaust off by tooth and a half? Or each cam is off a bit with crank at tdc...etc. You know what to look for with a leaking tensioner?
Is there receipts for the belt change? If there isn't, we can assume the seller lied and your belt is overdue. Redo everything with OEM tensioner and pulleys. Your choice of belt but OEM or better. I've gotten some of the name brand kevlar belts cheaper than OEM before.
We pulled everything apart and discovered the balance shaft belt ripped which caused the jump.
Sounds like they changed the timing belt but didn't do the balancer belt. More often than not occurence. I found the same thing when I first tore my motor apart and the belt was supposed to have been done at the 60k mark but I had better luck than you.
Gonna buy one from my local parts store just to go to mod and back and then buy everything oem timing wise. So you think my motor will be ok? It jumped a tooth and 1/2 when we aligned the marks tdc. It only had 84k original miles :(
I can't tell if its just the picture or not but it looks a little wet in the timing area. Personally, I'd park it until you can repair it correctly, which may possibly include replacing some seals either on the balance shaft, oil pump or the crank shaft. Oil on the new belt will cause it to fail right away.
If it ran with the timing that much off I don't see why it won't with the timing correct.
It's weird when it happened. I drove home from work fine, parked the car, and washed it. As soon as I started the car, it started idling low and bogging when I tried to drive it. Luckily when my brother tested the car it didn't get worse because he did a lil pull and nothing jumped nor any knocking was present. After that, we parked it and never turned it on since.
It's not wet, the flash on my phone made it look like that. We checked everything else and it's fine. However, I'm replacing the the whole timing with brand new and oem components when I come back from MOD
U can re-assemble your timing belt long enough to perform a compression test. If u have good compression on all cylinders your motor survived.
Too late. Looks like you're in good shape.
He mentioned he already ran the motor with the jumped belt. Not sure how a compression test would punch holes in pistons... Unless valves were already mangled
Besides he already fired it up.
I was referring to your suggestion in general.
If a motor jumps time just enough to bend a couple of valves, the engine will probably die almost immediately with a just a kiss or two on the piston tops. Putting it back together (new t-belt, resetting timing, etc) to do a compression test without knowing the full extent of the damage is asking for more trouble. Cranking on it and banging bent valves against a piston until they break off and possibly do more damage to the bottom end isn't something I would want to do.
A static leak-down test at that point is safer for the motor, and will tell a lot more about what is going on. If the leak-down test checks out, then do a compression test.
  • Wanted 6 bolt NT water pipe
    • chrisman287
