OH91awd
- 1,204
- 767
- Sep 22, 2011
chillicothe,
Ohio
so to try to keep things simple i took my car apart to fix a few issues/ maintenance stuff. i took the intake for some more room to fix some brake lines that broke and also sent injectors out to be cleaned. the car ran fine before taking it apart. so i got the car back together and take it for its first test drive. first it didnt start like it used to (car would fire right up no matter the weather, now it takes a minute) start to make a pull in the car and it just feels like its hitting a wall in rpm and wont build boost and can kinda hear it sputtering/ breaking up. afrs seem fine (not too rich or too lean that i remember). some info on the car that might pretain to the issue.
auto car. did seem to do ok stalling up and getting on converter before drive (4200rpm 2 step)
intake has phenolic gasket on (its probably 6-7 years old)
car is on sd and e85.
plugs are kinda old (2 years i think)plan on changing those next.
injectors are fid 2000s that were just cleaned by mike at buchur racing.
i havent taken a log yet of it to see if that shows anything. it was kinda late when i drove it. im open to any suggestions or things to check to try and fix this issue.
). car has sat a while which i know doesnt help things either..
