Can't get over 3.5k rpm, high knock...
gijoe985
562
20
Dec 13, 2007
Grandview, Washington
Hey all,
First off, I am going to come right out and confess that this isn't on my DSM. It's my 3kgt VR4. But the guys on the 3si forum have not been much help and I feel that there are more people on here with more experience.
Anyway, here is what I've got happening..
Got this 3kgt, was supposed to have engine problems, tested good on leak down and compression, so I started it up. It idles alright, but cannot go above 3.5k rpm. It also has a high knock count. I get up to 26 or so. I can't find any vacuum leaks. I've sprayed around with carb cleaner, and had no luck. I rechecked the static timing and checked again with a light. Looks good.
I'm attaching a MMCd log to hopefully give someone smarter than I a clue.
And here is a link to my 3si post, maybe some more info on there.
High knock, won't go over 3k rpm, fuel trims, timing... - Page 2 - 3000GT/Stealth International Message Center
Sounds like its leaning out like a mother. First thing I would do is check fuel lines/filter/pump.
It also could be an electrical problem.
I would say do that first. I am not sure of how that would work since there are different fuel maps.
When your at a standstill can you get past 3.5k?
do you have any mods done to it? are you running any kind of fuel controller? as said above you are leaning out really bad and your fuel trims are way off as well if i remember corectly your fuel trims are like a 1g they are suposed to sit at 100 and if they are like a 1g then you are running rich at idle... but yet your o2 voltage is showing you are lean.... have you replaced your o2 sensor? fuel filter?
It does have a cat delete downpipe, MBC, and boost gauge. Also has vacuum delete. I don't think there is anything else done. Or at least that I notice.
I hope to check fuel pressure later, as long as I can find a place where I can tap in...
Also, the short term fuel trim shows rich, but just the other day it was sitting at 110%. So I don't know why it just had the polar shift...
Check the plug wires, my buddy had a 1990 talon tsi, couldnt get it passed 3k even when he floored it. He was getting lost of knock also. He put a new set of plugs and wires in it and it took care of the problem. Not saying that this is it, but its someting to consider.
Yeah, already did that, but I am going to try a power drop test... Make sure it is firing on all of them...
So supposedly this car was running fine, just had the engine rebuilt, and then it died on one of the first test runs. Considering the lean state, maybe the fuel filter collapsed? I need to do a pressure test, but have not figured out how yet. I have a t fitting that I could use to get in between two 3/8" fuel lines. Is there a place I could do that? I've actually never even seen the fuel filter on these cars. Underneath I assume...
