pgcanillas
- 0
- Aug 4, 2008
Bs As,
South America
I need help with the following: After 5500RPM, I start having a lot of knock (more than 20).
My car has an OEM 14b, an OEM I/C, 255 lph, stock fpr, 550cc Injectors, 2,5" exhaust, no cat, 2,5" downpipe, and an upper I/C pipe. I also have an Apexi AVCR, and a SAFC, plus an AEM WideBand, and a pocketlogger. My plugs are BPR6ES gapped at 0,3.
I am suffering of boost creep, so I decide to make the fuel upgrade, in order to do not have to worry about this. So I am running 17 psi, which is the lowest that I can.
The problem is the following, I have tune my fuel curve to be between 10,3 to 10,5 while I am at full throtle, and under the Boost. The car goes well up to 5600RPM, and then the knock start, and pull my timing up to 10 degrees ( the maxium I see at 5500 rpm is 18 degrees), making the car feels slow.
How can I solve this? THANKS!!!
PD: Excuse my English, I am from Argentina, and my natural language is Spanish.
