cant get boost past 10psi
talon913
244
Nov 21, 2008
olathe, Kansas
ok so this problem came up sudden...... last week i was getting 14-15psi constantly without any hesitation.that was with out a mbc.i flipped my bov upside down and now i was boosting only 8psi.i unhooked the wastegate line for a sec and was only gettting 10psi tops it wouldnt go past it..i even put silicone around the bov flange to make sure no leaks.i have a 190 fuel pump installed a couple days ago.and a mbc.i had the mbc on correctly and it was open almost all the way and still no boost past 10psi.feels like i lost a whole lot of power.could this all come up to a bad boost leak some were:confused:
ya it most likely is a boost leak some place, did you check all couplers to make sure they are tight? just do the leak test just to be sure. mine did that too when i had a leak couldn't boost past 12.
Do a boost leak test. I had a bad diaphragm in my Greddy RS that was causing a BAD leak. You still have it recirculated correct?
Check for boost leaks and make sure the BOV's actuator line is securely hooked to the intake manifold.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
