Can't get past 10psi
SleepingTsi94
261
Apr 24, 2006
Corn, Iowa
My car wont boost past 10 psi. I have checked boost leaks a week ago found a couple and fixed them. All seemed to be working fine from there. Now I try to switch from low to high boost on my greddy profec b and it stays the same. I have it so the out on the control motor hooks up to the top of my turbonetics evolution wastegate and the in to compressor housing. And the vacuum line on the ebc its self hooks into the afpr. I have checked over and over for vacuum leaks and can not find any. I may have some very tiny exhasut leaks which I will fix. What are some other things that could cause this?
It sounds as if the pressure signal going to the wastegate isn't being delayed. As if you were running a line directly from the compressor to the wastegate. I'm not sure what type of controller the Greddy uses (stepper motor, solenoid, etc.) but it might be stuck in the open position.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
