Cant boost past 18psi?
Rob88
74
Jul 1, 2007
Portland, Oregon
Its a GVR4 88k miles 20g turbo 880cc injectors comp cams (10200 i think) arp head studs fel pro MLS head gasket ecmlink v3 (SD setup) ETS FMIC FP race manifold ported evo III o2 housing to a 3" DP and an electric cut out. INO MTX WB.
So my problem is i can only make around 18 PSI before the car starts to what sounds like backfire out the exhaust at higher RPMs happens sooner with more boost and is worse if the cutout is open rather then running stock exhaust. if i run it with the cutout closed through the stock exhaust and around 15-16 psi the car runs great.
attached 2 logs. one where it runs fine the other where it breaks up. you'll see im not even running much for timing because im battling knock as well.
im gonna try taking the gap down and changing the plugs after work. i think i had them gapped at 26 im going to try 20.
ya gapped at 20 it pulls very strong. :thumb: problem solved!
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
