Cant crank car
gs2048
Jan 11, 2021
Chino, California
Hey guys, recently got a 98 GS-T and in the past the wiring harness caught fire but was replaced yesterday, everything works from it, however, I cant start the car because the key wont go past accessory, it says anti-lock and Im thinking its the anti theft, is there anyway to get around it and start it? Could it possibly also be the starter thats the issue since the key wont turn past it even when pressing the clutch/brake in all the way to unlock the wheel?
Nevermind, Im able to turn the key past where the car is supposed to crank but hear a little noise but thats about it, doesnt crank at all
back in the day, i picked up a gst with a fire damaged engine bay. after a shitload of work fixing, replacing, upgrading, i thought it would fire up, nope. i had the same starting issue as you. ended up the fire was put out with a water hose and the water had gotten into the cylinders. The pistons were rust welded to the cylinder walls.
pull the spark plugs out and see if you can hand turn the crank using a socket/ ratchet on the crank bolt
What do you mean by a little noise? Does it sound like the starter is trying? If so, i would check the main engine ground (located on the upper bolt on the starter from the factory). If it just sounds like a relay clicking I would check your getting signal from the key at the starter.
Just pull the ignition switch out from the back side of the ignition cylinder and turn it to start the car. It'll bypass the cylinder/key. So if it starts that way, then the problem is within the cylinder.
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
  • For sale 2g 2G Auto Shifter Base
    2G Auto Shifter Base $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 1g Mishimoto radiator
    Mishimoto X-Line Aluminum Radiator | 1990-1994 1G DSM (MMRAD-ECL-90X)
    • william
