2G Key not cranking
gs2048
Jan 11, 2021
Chino, California
Hey guys, recently got my 98 gst spyder back up and running but not in a conventional way, whenever I go into the car and turn the key to start the car, it doesn’t do anything but click, so I made a wire from the starter to the positive terminal of the battery and that cranks it over just fine and thats how we drove it after two years of sitting back to my house but still cant seem to find out why the key isn't engaging the starter to crank over the car, can anyone help me to try to find out what it could be/how to fix it?
Try unplugging the clutch switch. It’s the one closest to the firewall. If that doesn’t work, you’ll have to check why the starter isn’t getting the signals from the ignition.
here is the theft system section of the manual if you need it. 97-99 anti theft system
If it's not the clutch position switch or the starter relay under the dash there is 1 wire connector between the starter harness and the main harness. it's located behind and below the thermostat housing. THis wire carries the start signal from the starter relay to the starter. Make sure it's plugged in or the wire isn't broken.
2g Engine Bay Electrical Connections | Page 2 | DSMtunersI
It's post #41 in that link.
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
  • For sale 2g 2G Auto Shifter Base
    2G Auto Shifter Base $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 1g Mishimoto radiator
    Mishimoto X-Line Aluminum Radiator | 1990-1994 1G DSM (MMRAD-ECL-90X)
    • william
