ECMlink Can't access direct access in v2.5
whiteboyz
244
Jul 21, 2009
Albany, New York
Ok so I am having issues, everytime i trun my battery disconect switch off, I lose all the settings in link and have to start over again each time:banghead:.
I read on the wiki about saving it in direct access, But I get a popup that says This ecu does not support direct, byte-level access.
So I can not even force the save thru direct access.
Any suggestions would be awesome thank you very much.
That's a known issue for 2.5. Either reload a tune after disconnecting the battery or upgrade to v3.
DA is only for v3.
Ahh Ok thanks Brian. It just stinks having to dial everything back in again. It always resets to the old setup with 950's and I am on stock inj's atm.
I thought it was something I did, when I relocated the bat to the trunk.
How do I reload a tune after the battery is disconected? As soon as I shut the battery disconect switch off the ECU no longer has power. As the MFI relay that powers the ECU also looses power.
I was wondering if maybe I could just run a wire with an Inline fuse from my pos side of the battery to the power on the ECU or the MFI relay. Or is that a bad Idea ?
Again thank you Brian
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
