Can you convert a 94 Talon ES to TSI
Alconchino
34
May 15, 2011
LovesPark, Illinois
i want to know if it is posable and what do i need and a gesstamate
on how much will it cost if its possible
can you convert a talon es 94 to a tsi like replace the motor and transmison from junk yard and new cpu and new instamte cluster?
So you want a fwd tsi, or an awd tsi?
Yes it would be easy on a fwd..You would need engine,harness, ecu, tansmission, cv shafts..
Unless you wanted to go the even cheaper route and turbo the n/t..But you willl be limited to about 8psi..
