Can you convert a fwd auto to awd?
Jonnynitrous
148
Nov 30, 2010
T bay, ON, Canada
I Have a 90 talon awd 5 speed and I'm on the look for a auto. Now there is a fwd auto at the scrap yard and I was wondering if it could be coverted to awd?
I haven't seen what a fwd case looks like so I have no clue
Thanks
They are not the same transmission, so no. When someone converts to AWD they swap out the transmission and have to get a transfer case, the drive shafts, carrier bearing, rear differential and CV axles along with other important components.
Aside from the obvious fact that you cant put the parts from an Auto in A 5spd case or vice versa
Also to add to that Any Fwd Trans you have isnt going to have a place For the center dif or Vc
So a big fat NO
Also I'm pretty sure that AWD was not available in the automatic.
WTF Do you live under a rock?
That was a mistake and could not get back online fast enough to fix it. I was thinking of the Plymouth lasers option package.
They are not the same transmission, so no. Also I'm pretty sure that AWD was not available in the automatic. When someone converts to AWD they swap out the transmission and have to get a transfer case, the drive shafts, carrier bearing, rear differential and CV axles along with other important components.
What?? Edit that so I can take you seriously.
Thanks for the responses. Thought I would get lucky and they used the same case.
I wasn't thinking of putting auto parts in a manual. I was wondering if the fwd auto case was the same as the awd auto case. LOL thanks again
