How to convert an ESi --> TSi
kmetiuk
521
126
Mar 10, 2010
Edmonton, AB, Canada
HAHAHAAH!!! Can't be done!!?!?!? Too late did it!!!
http://www.dsmtuners.com/forums/dsm...i-4g63-awd-evo-8-he351ve-project-warface.html
My new issue is this:
Project has taken a drastic and exciting turn....
I JUST ENTERED THIS RIDE INTO THE LEDUC 1000KM RACE!!!! 370 laps = 9-11 hours of fcuuuuuuuuuuuuuuuuuuuuuck ya!
God I am pumped. Only 2 months to repair the blown water pump and then 6 more months to get it ready for the big race. Not missing much at this point....
Its mostly been shaken down to....I bag the fcuk outta this thing EVERY time I take it out (in a legal and very controlled way of course) so I should have no surprises.
I do have one question for anyone that's listening...
What are you thoughts on transmissions? LSD's? Dogbox vs a stage 5? Clutch packs (the ACT 2600 kills my leg after an hour or so)
Obliviously my power levels will warrant this...we're shooting for +35psi on the track...its a twisty mofo with a few very long stretches so I am worried about pounding on that tranny for 9-11 hours straight
Literally the last few things I have yet to finalize.
I am thinking a twin plate sprung clutch with a shep/jacks stage 5 with quafie front, back, and center.
Thoughts?
I'm also in Edmonton, didnt know about this race but I plan to take mine to the new castrol raceway track at least a few times this year. Dunno if it would last for a 1000km race tho.. heh I know in the endurance races, brake heatsoaking becomes a major factor.. Do you have drilled slotted rotors? I managed to heatsoak my stock brake system in less than 15 minutes of hard racing, and you can tell instantly when you go to push the brakes and you can't stop heh. Id be concerned about that. Also I'm using the exedy stage 1 organic sprung clutch disk with fidanza auminum flywheel.. I believe it uses a 2300 lb pressure plate, its still not to hard on the leg and the aluminum flywheel helps to dissipate the heat. A cool clutch will last longer. Not sure if it can hold the types of power your talking about tho. Maybe the competition clutch twin disk is a better match for your needs.
Oh by the way, if you need a brand new OEM release bearing or clutch fork, I have these I can part with for $25 bucks each. Saves you time and shipping.
Also, do you have professional welding experience? I notice some of your body work looks impressive. I may need my rear trailing arm mounts replaced in a similar fashion some time, not sure who can do this work correctly..
