2G can I use a 96 talon FWD M/T engine harness without abs in 95 talon AWD that had abs
shifttsi
62
3
Jun 19, 2013
Wallingford, Connecticut
Hey guys, Ive searched and searched but there were no specific results to my question. I have a 96 Talon TSI, FWD M/T non ABS and I bought a 95 Talon AWD M/T with ABS shell that I plan to build from my 96 talon.
I need to know if I can use my entire Engine harness from the FWD Talon for the AWD. I already pulled the AWD harness out since it is a shell it wasnt too difficult. I pulled the Driver side portion of the harness from the FWD and just noticed a few more wires in one of the connectors which should be the wheel sensors and other abs components I would imagine.
Please note, I already pulled the ABS system out and used the STM abs delete kit so I know the car will not have ABS anymore!
I am also using the ECU and engine from the FWD since I spent 3yrs building it!
So long question short, Can I use my 99 non abs harness in my 95 which used to have abs? I appreciate any and all support Thanks!
Hey, Thanks for the quick reply. I am 50% complete removing the harness from the 96 so I will know soon. Im hoping I dont need any modifications since I am using the harness, engine, and CPU from the same car. Would you happen to know if I will have some kind of ABS/AWD/ or other warnings on the dash when I do the swap? I would imagine not or am I wrong?
My next question is the MPI and MFI relays are different between the 95 and 96. The 95 had the one solid relay pictured below but the 96 had the two seperate relays. Would I be ok swapping these or will something get screwed up when I try and start the car? I guess the 95 was OBD1 even though it has an OBD2 port..
I wouldn't see why not. Other than the abs you already mentioned, they should be the same. The CAS will be different, but I don't think that's part of the section of harness you're dealing with anyway.
'95 and '96 use the same style CAS.
Only differences I can think of would be the ABS portion of the harness, and a '95 harness would have that extra timing connector on the firewall.
Agreed. Thanks. I figured it wouldnt be an issue especially because the motor, harnesses, and ecu are all coming out of the same car. This leads me to my next question.. The car is a 95, I was told it is OBD1 but it has an OBD2 connector under the dash. Are emissions going to be done with the sniffer or OBD2?
Thanks for taking the time to answer my questions guys. I am looking through the threads now for some answers as well.
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
