Can I start Rebuilt motor wit no TPS n Knock
Streetsweeper21
140
Jan 11, 2006
Atlana, Georgia
Alright im puttin together this 2g for my girl friend with a 6bolt motor and everything is pretty much in place what I want to know is would it be okay if I temporily dont plug up the TPS and Knock Sensor until I get them. for the first start up. Everything is freshly rebuilt with aftermarket internals.
Also I have a stainsteel clutch line and there is cylinder thing b4 the slave cylinder do I jus replace it with the stainless steel line because thats where the ruber hose starts.
I do know that the car won't do much more than idle with the TPS not plugged in. Why can't you plug those in?
The SS braided 2G clutch line is designed to eliminate the accumulator. You can also use a 1G line and eliminate the accumulator yourself. I'll post a picture this afternoon of what I'm referring to.
I need a 2g Tps sensor and only have 1gs Tps sensors it plugs it but its not the same part number compared to the 2g.
So I was right I thought it had to be eliminate since the SS line was so long thanks alot and thanks for helping me on my other thread with my 1g.
